Question about Skull Candy Agent Headphones
Onli getting sound out ov left headphone - Skull Candy Agent Headphones
Posted by derbycounty2 on
Grubhead
  • Skull Candy Master
  • 5,720 Answers
See my tip on replacing dodgy cables plugs on headphones. Just click my name. Follow the steps to see if you can track it down, it could be the plug!
Posted on Dec 04, 2010
Vy my low beam r/h/side is very dull an my fog lights come on with out the switch but they r dull as well iv taken my left and right fuse out both have power 12.7 volts checked the input side ov the fuse...
clean up the earth return cables and mountings as sounds like poor earth return, try a continuity test from earth at the lights causing problems and see if getting good earth
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
6helpful
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
3helpful
2answers
No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Skull Candy Agent Headphones Logo
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
ADMIN Canada
ADMIN Canada
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
