Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Furnace lights briefly but wont stay lit - Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Posted by i_downing on
Robert Horton
  • 1,515 Answers
Hi sounds as though you have a dirty flame sensor that you need to clean. On a propane unit, they tend to carbon up much faster then a natural gas unit. The flame sensor is located next to the pilot, and has a metal tip that rests in the pilot flame. Most are made of porcelin and will have a electrical wire coming out of the back that is connected to the module or circuit board, which ever you have. When they get dirty, they cant get hot enough to produce enough milivolts to tell the ignitor module that the pilot flame is established, and will shut the unit off. This will happen about 3 times until it is locked out. Just use a piece of fine steel wool or sanding cloth to clean the tip, and this should take care of your problem. If the problem continues, please let me know, and we can check further into it. You may have a ignitor module that you are loosing, or ignitor board. Please keep me posted on this, as I am sure cleaning the tip will solve this problem. Please rate me! 4 thumbs up would be great!
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Nov 19, 2010
  • Robert Horton
    Robert Horton Nov 20, 2010
    Hi, checking in with you to see what is up!
    Shastalaker7
Furnace not staying on
Could be thermostat or safety switch(es) in the furnace. Are you sure that the pilot is staying lit? Are you sure the main burner is lighting? Are you sure the forced draft blower is running, and the blower-detection "flapper" switch is working OK? Any of these safety devices will cause the gas supply valve to close if they are not "satisfied" in a few seconds after the thermostat calls for heat. They keep your RV safe!
Oct 17, 2016 | Dutchmen 2012 Denali 310RES
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
Pilot light on Tempstar furnace wont stay lit. replaced thermo-couple and it still wont stay lit. what next???
Do you have a good pilot flame? Is it wrapping around the thermocouple good? You may need a new pilot orifice.
Mar 07, 2014 | Heating & Cooling
We jumped the high limit switch and now everthing stayd on except it wont stay lit
There might be a sensor in front of the burners. Looks like a metal rod. Make sure power is off and carefully use a wire brush to clean the rod. It will only have 1 wire to this sensor.
Jan 20, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
The pilot light will stay lit. Go to turn on heater and stays on briefly and goes out The heater wont stay lit.
If the fan comes on and blows out the pilot light then you need a new furnace because that's the sign of a crack in the heat exchanger. Need a little better description. Do the burners light then the fan come`s on and then it goes out completely?
Nov 24, 2010 | Heating & Cooling
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
I can't get the pilot light on my furnace to stay lit.
take out the pilot assembly. there is a small burner and an orfice. the orfice does get clogged if it has not been operated for awhile. you can clean it out with a small sewing needle. if the pilot wont light or stay lit, replace the thermocouple.
Dec 06, 2009 | Heating & Cooling
Heating & Cooling Logo
611 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
