Question about Wacom Graphire4 4x5
My pen tablet stays clicked down, whenever I drag it across the screen it clicks everything. And then when I do press it down to click on something it doesn't do anything. I have tried to uninstall and reinstall, and have tried to download the updates but nothing works. Any suggestions?
Posted by arani_16 on
5 Related Answers
Anonymous
SOURCE: Initial Delay of tablet pen
i returned my Intuos 3 unit, replaced it. The new one works perfectly, it was a hardware defect for me.
Posted on May 19, 2008
Anonymous
SOURCE: Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
Posted on Sep 03, 2008
Anonymous
SOURCE: Wacom Tablet overly sensitive
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
Posted on Nov 02, 2008
Anonymous
SOURCE: Genius MousePen 6x8 pen drags as if I'm holding down mouse button
Listen up kiddos! I had this same problem and I was troubleshooting....apparently you have to make sure you uninstall the old drivers first and delete the directory entirely, before reinstalling the software.
So, UNPLUG THE TABLET! This is the part that screwed me up... then go to start > all programs > tablet > uninstall. Run the wizard, restart, go to my computer > local disk drive > program files and delete the Genius Tablet folder. Then, install the drivers again, reboot, THEN and ONLY THEN, should you plug your tablet back in.
Posted on Apr 11, 2009
Anonymous
  • 8 Answers
SOURCE: photoshop cs4 pen pressure not working. Windows
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu. Hope that fixes it for ya.
Posted on Jun 05, 2010
My Genius Easypen i405X tablet keeps clicking when I hover with pen
Hello :) we have the same problem regarding the same brand and product. But I got mine working just a while ago.
Try this: Control Panel>Pen and Touch
under pen options, there should be settings regarding the pen buttons. Unclick the "use the pen button as a right-click equivalent"
hope this helps though although it's been a year XD
Jan 11, 2012 | Computers & Internet
My Genius Easypen i405X tablet keeps clicking when I hover with pen.
Since you got this just a few days ago, you should take it back to where you got it and talk to them about what is going on. There is a warranty and you don't want to void that!
Mar 06, 2017 | Genius Computers & Internet
Pen Tablet Constently clicking.
if you are willing to throw $30 at the problem then you can get a new pen to replace it but otherwise i have not seen a fix for this problem yet. I am experiencing the same problem. But while this tablet is nice I might suggest to get a newer one that has more surface area that you can write on since you are already spending money. you could also take apart the pen and see if you can fix the inner parts. if you are feeling brave/ you know what you are doing/ you just want to see what the inside looks like.
Nov 05, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Just fully charged Sony Clie'---backlight is too dim..How to adjust??
You can set your pen drag function to adjust the brightness.
Click the drop down menu on the top right of your screen, then click "system", then "prefs", then click the button at the bottom of the screen that says "pen". Next, click the drop down menu beside the little icon that looks like your clie. Click that and select "brightness". Now, when you drag your stylus from the bottom to the top of the screen, a little slider bar will appear to adjust the brightness.
Sep 14, 2009 | Sony CLIE PEG-UX50 Handheld
My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
Sep 07, 2009 | Wacom (PTZ930AC) Graphic Tablet
My Pen Doesn't Work
ya, i had teh same problem ... i had recenlty downloaded "pen attention" its a software that some guy made to make the pen curser look bigger in one note ... i uninstalled this program and now the problem is gone!!! so just make sure that you delete any programs that you have downloaded tht might be interfeering the the tablet's performance (especilaly programs or addons that my have been developed by non-wacom personelle for the tablet)
Jan 09, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
The mouse on my Wacom Intuos tablet is not working.
I know this question was asked a long time ago, but I just had this similar problem and found a solution to it.
1. Install the latest Wacom drivers for your device
2. Open the Wacom Tablet Properties from the Start menu.
3. Click on the Mouse tool
4. Click on the Mapping tab halfway down the screen
5. Change the mode from Mouse to Pen
Dec 26, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Wacom Graphire4 4x5 Logo
Top Wacom Computers & Internet Experts
k24674
Harrie
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
