Question about Epson Office Equipment & Supplies
How do you load new printer cartriges - Epson Office Equipment & Supplies
Posted by lclaydon1 on
Esther Lim
  • 270 Answers
To replace an ink cartridge using the How do you load new printer cartriges - fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The power light should be on, but not flashing.
2. Lower the output tray, then open How do you load new printer cartriges - fonth.gifer cover.
3. Press the fonth.gif inHow do you load new printer cartriges - fontp.gif The print head moves to the ink cartridge replacement poHow do you load new printer cartriges - fonth.gifhe fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not applyHow do you load new printer cartriges - fonth.gife force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and thHow do you load new printer cartriges - fonth.gif cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. How do you load new printer cartriges - fonth.gifess takes about one minute to complete. When the ink cHow do you load new printer cartriges - fontp.gifrocess is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Posted on Nov 19, 2010
Kat Pulami
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
If the printer is inkjet
you have to remove air block sticker from cartridge before inserting cartridge into print-head.
if the printer is laser
you have to pull out plastic protector from cartridge befor inserting.
Posted on Jan 03, 2015
Gail Keys
    New Friend:
    Problem Solver:
  • 10 Answers
1. First remove the sticker and transparent tape completely from the bottom of the cartridge.
2. If it is already open, press down on the cartridge lever to raise the cartridge lid.
3.Insert the black cartridge or photo cartridge in the left carrier or the color cartridge in the right carrier.
4.Snap the lid closed.
5.Close the access cover.
Source "http://www.printercartridge.com/ "
Posted on Sep 22, 2014
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Ink cartrige cannot be recognised
make sure you've taken the protective tape off the cartrige. Usually its orange and noticeable.
Sometimes generic cartriges have a small chip and a registration that allows the printer to talk between the cartrige from what I under stand maybe ink levels and to protect profits on not allowing generic companies to make a more economical product competitively
the printer can sometimes be power cycled to allow it to accept the generic cartrige.
there are normally settings on a printer to see if you can change the internal settings can be altered to allow non Original Electronic Manufacturors products in a Canon Printer.
make sure that the type of printer you have is compatible with the printer. the computer may require a black cartridge or a color cartrige in a very specific location. they might not be allowed to be switched.
make sure the cartrige can slide in and out of it's slot comfortably.
FOR office printers. there are also protective tabs holding the ink in the cartrige. this side tab on the cartrige is there for shipping. these are normally on large 30 pound printers. top front loading Office printers. the tab needs to be turned hard and swift either clockwise or counter clockwise if you can't cleaning pull it out. Also remember your boss paid a lot for that cartrige dont break something your not comfortable breaking. be warned in advance this dry ink will spill and is hard to clean and harder to clean from clothing.
as per a fast solution a smaller printer and certainly a cartrige can actually be brought into a computer and electronics store whilst looking to buy a new print cartrige. Make sure if you do bring a piece of your own electronics into a store you check in with security. let them know its yours; wave it in front of a camera if youd like.
the seller normally should be able to recognize if their product will fit in your device it will save both of you time and inconvience.
cartriges cost about the same as a new printer with new ink.
dont be afriad to buy an extra ink at the time of purchase and risk letting it dry but having the back up that you know works-
you'll have a package for the next time you need a new cartidge. gives you more research material.
accept moores law
feel good about flossing on a new printer.
print some pictures and frame them-
pictures are some of the most important thing in our lives! Smile!
Mar 10, 2010 | Canon Office Equipment & Supplies
Refilled printer cartridge
Sorry if you do not like this answer, but it is the truth.
Lexmark does not support the use of OEM or third party cartrideges.
Lexmark, considers this to be product tampering and will void the printer's warranty.
Don
Jun 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Receiving a flashing E followed by a 5 on the digital display.
One of the cartrige must be changed with a new one(or another good cartrige).I had the same problem with the colour cartridge.
Jan 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I load a new printer cartridge into a MFC 3420C
read the manual in ur service manual that is installed in your pc then click cartrige replacement
Nov 28, 2008 | Brother MFC 3420C All-In-One InkJet...
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Wrong cartridge
Nice Printer.
First of all, see if its reading on the computer, if not, try and hold the power on the printer untill it shuts off, and then turn it back on again. Also, you might want to check the troubeshooting section if you have the manual
If none of the above works, try getting a replacement cartrige. if the connectors on the cartrige get messed up, the printer may not read the cartrige properly. Make sure the printer's connection to the cartirdge is ok too. If you know someone who has the same printer, try the "ERROR" cartrige in that printer. if it works, then your printer needs to get fixed. If it doesn't work, get a new cartrige and all should be fine. Don't get the cartrige refilled if it doesn't read in a nother printer, you need to replace the cartrige!
Jul 17, 2008 | Computers & Internet
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
533 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
