Question about Brother Sewing Machines
My machine is not getting any power. I took my machine to a class yesterday. It worked fine but when I plugged it in here at home last night, nothing happened. I checked the outlet with a lamp and the light came on. Could something have happened to the power cord? It was stored for transportation in a padded compartment.
Posted by marvella329 on
Debbi's Sewing Machine Repair
  • Brother Master
  • 7,365 Answers
It is possible the power cord has gone out,,or the power cord receptacle has gone out
i've been working on a sewing machine that they connected the power cord & disconnected it so much that they pushed the pins out of there sockets
or the on/ off switch has gone out
Posted on Nov 19, 2010
I plug in and there is power to the machine because the light comes on. but when i plug in the foot pedal nothing happens
It sounds like it's in the electrical system and I would worry that it might short out and cause a fire.Get another opinion.
Sep 11, 2015 | Sewing Machines
I just got this machine 2 days ago.. used.. but only 29,000 stitches on it.. took it to the service center yesterday, had it checked out top to bottom.. the tech said. great machine.. works wonderful..all...
When you say you used needle 1-5, then needle 6 messed up, are you saying you actually inserted six different needles into the machine, one by one ? If so, and the other needles work, then chances are the sixth one is defective in some way. They can have burrs on them that cause this kind of issue, and the solution is toss it out and use a new one.
If it means something else, need to know model and make and just what all this needles are for.
Nov 02, 2014 | Sewing Machines
Futura XL 400 all lights flashing
could have a short in the machine or if the machine is computerized there could also be a problem there.
Mar 25, 2014 | Sewing Machines
Interrupted power on my Pfaff sewing machine
Make sure your machine cord secure in the machine. Check your home wall outlet too since you are able to get machine running away from your home. If none of these are the issues, definitely take back for repair. Jimmy
Apr 03, 2012 | Sewing Machines
Just bought my new machine yesterday and excited to start using it. I read over the manual last night. There is a DVD but only the audio is working on it. How can I get a new DVD or is this something...
not sure why dvd wont work unless you bought machine online from another country? if you did, double check voltage on it is same as yr power supply. now to get started, visit youtube or www.sewing.about.com and check out general sm info if you are a newbie. debbie has simple projects online which you might want to make as starters, such as a cushion cover or apron. if you have never sewen then consider taking a class or two to learn skills such as cutting out a pattern and garment assembly. for now why not wind a bobbin, thread up refering to manual and try stitching straight stitch seam and then zig zag the raw edges. enjoy!
Aug 08, 2011 | Kenmore 19233 Computerized Sewing Machine
I used the machine yesterday. When I went to sew somthign else, the light went on but when I went to pust the foot control I get nothing. I have cleaned the inside and it has been unpluged since last...
Check to see if the cord leading from the footpedal to the machine is loose or frayed?You might have accidently loosed it when you were cleaning your machine.
Jun 30, 2011 | Janome D'cor Excel 5018
Hello, I have a computerized PFAFF Hobblylock that doesn't work
My Pfaff dealer in CA gives free estimates. He recently took my sewing machine apart to determine that it had a bad board.
Dec 19, 2009 | PfaFF Sewing Machines
Singer FUTURA CE-250 beeping at startup.
you have a bit of cotton blocking a sensor or lever. normally the one that tells you ran out of cotton.
Oct 03, 2009 | Sewing Machines
Sewing Machines Logo
136 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
