SOURCE: Schematics
Dclf1
Good day!
First things first:
1) you only can find those schematics on
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
but have to call or email support.
hope they can send the info.
Open Sky
SOURCE: Labtec LCS 1024
Do you have any schematic of Labtec 1025 with wiring conection? Thank you for your response it does help me alot
SOURCE: labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
SOURCE: no wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
SOURCE: Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
I thought they used an AC adapter and it was 6 volt?
