Maytag MMV5207AAS Microwave Oven Logo
Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I had used my microwave extensively in one day , and now it's not heating anymore, the timer goes on and then it peeps 3 times that it's done but the food or water remains in the same temperature. Help please
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Feb 25, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10845069
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Why microwave does not heat anymore
Well, we are looking at a bad magnetron, cracked high voltage diode, or a shorted high volage capacitor. I would suggest replacing the microwave oven because the expence involved to have it serviced.
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Hello, When you turn the unit on the digital timer starts & the light goes on but there is no power to the tray motor, fan, or microwave power unit (the food does not cook). It makes no noise...
It sounds like the oven needs to finally go to home. Some things take more time and headache to fix than just to go get a new one.
Just an FYI note, look up health hazzards of microwave ovens, you might be surprised and not use them anymore like we stopped. It's very bad for us.
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
heatman101
My mh2175xsb microwave quit working a few days ago, that is it pretends to be working. All functions appear normal, timers, lights, fans, and even cycles when on percentage heat, but it heats nothing. The...
Hello Keith Sprague,
Spelling is close and your guess is quite excellent...
Before you ENGAGE in a wholesale repair effort...
You should check your machine is not in DEMO mode...
Demo Mode
Activate to practice using the control without actually turning on
the magnetron. Touch and hold number pad "3" for 3 seconds. The
"DEMO" icon will appear in the display. Repeat to exit Demo Mode
From page 3 (of your operators manual)
Whirlpool MH2175XSB User Instructions Electrical Requirements
Hope this helps
Carnac the Magnificent
MY PANASONIC MICROWAVE SHUTS OFF AUTOMATICALLY AFTER 3 OR 4 SEC
Sure sounds like it is losing power. First check the fuse and fuse holder. These companies are using really cheap fuse holders and they do not grab the fuse tightly, thye get hot and start to melt the fuse. Remove the fuse and look for signs of heat or flux running from the silver ends of the fuse. if you see signs of it being hot I would replace the fuse and fuse holder. Make sure ALL connections are tight and give it a try. I search long and hard to find fuse holders I like and can trust to do a long term repair. if you cant count on a part, the repair wont hold up and then Its MY reputation that suffers, Damn companies always choosing the cheap way out on making parts. When I started repairing Microwaves, a Home Microwave cost about 800.00 I see them sell at certain stores for 18.88!!!! how can you have good parts in there for 18.88?? Nobody makes things to last anymore. SAD!!! Fill The landfills and buy a new one. except the new one is Cheap Garbage!! Since it goes blank it sound like it is losing power. Always could be outlet you have it plugged into. Try different location first, on different breaker
10helpful
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
67helpful
7answers
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
MICROWAVE COUNTER TOP
If you could post the brand and model that would probably helpus help you better.
3answers
Problem with microwave oven
F3 means a problem with the keypad. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. An exploded view and parts price list can be seen by entering your *entire* model number at the GE parts Web site: http://www.geappliances.com/shop/prts/
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
