Question about Tamron 28-200mm f/3.8-5.6 LD Aspherical IF Super II Macro Autofocus Lens for Minolta
When I look through the viewfinder, everything is very dark, I can barely see what I am trying to focus on. The auto focus does function but it is hard to determine what I am looking at. I can take a picture but it is very dark. The camera does work with another lens so it appears to be a problem just with this lens.
    Genius:
  • 1,177 Answers
Sounds to me like the aperture diaphragm on the lens is stuck in a small opening position. If you detach the lens from the camera and look through it, is the whole opening light or just a small dot in the middle? The diaphragm can stick if it gets a drop of oil on it.
Posted on Nov 19, 2010
6ya staff
SOURCE:
Canon 450D viewfinder out of focus due to loose element within viewfinder, is this repairable
There's a diopter adjustment knob above and right of the viewfinder. Turn the knob while peering through the viewfinder until it comes into focus.
Jul 29, 2012 | Canon EOS 450D Digital Camera
When I look through the view finder window. Everything that I see is out of focus...even the little numbers at the bottom. The pictures come out fine in Auto focus, but in any other mode, I can not tell...
Okay looking at the back of the camera where the viewfinder eye piece is right side upper corner you will see a small wheel partially covered by the rubber rim of the viewfinder by the side of it you will see a small line with a + and - that is a diopter that actually tunes the camera viewfinder to your shooting eye. Pretty fancy eh? Anyway what I do is set the camera in auto focus and focus on an object in a brightly lit room and when the little green light come on in the lower right corner of the viewfinder which is the auto focus confirmation light start turning this wheel one way and another until the image you see come into sharp focus. I don't know about you but I need about three clicks to the + side before everything looks sharp.
Dec 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My canon rebel xsi is not letting me take a picture on auto focus
It is possible you are trying to focus on somethind that is either completly white or completely black. It has trouble focusing in the dark as well. make sure your auto focus point (The red dots in your view finder is in the centre. you can move the red dot with the button on top of your camera that looks like 4 squares. simply look through your viewfinder push the shutter button down half way and the red dot should flash. if it isn't in the centre then move it with the button on top (4 squares) and try again until you get it in the centre.
Aug 16, 2010 | Canon EOS Rebel XSi Digital Camera
D80 Nikon - dark in viewfinder
What you see through the viewfinder is not exactly what you get in your picture. It is possible that your settings are just off in the camera. To make sure that this is the problem, set your settings to Auto and try again.
The red light before the picture is taken is a setting you can turn on to indicate that you have focused correctly. You can turn this off in the menu if this bothers you.
Lastly, I do not think your camera is broken. You just need to read your manual to make sure your settings are correct when you take a picture. Hope this helps.
NOTE: Please rate our help to keep this free service online
May 08, 2009 | Nikon D80 Digital Camera with 18-200mm...
My d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Auto focus
If you were doing close up- did you switch to Macro? do bare in mind that in close too situations, the focus sensor it looking at something different to the viewfinder[Parallax syndrome]
Jul 13, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Illuminated auto focus frames in the viewfinder
Yes, one of three auto focus frames will be lit up in the viewfinder.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Tamron 28-200mm f/3.8-5.6 LD Aspherical IF Super II Macro Autofocus Lens for Minolta Logo
195 people viewed this question
Top Tamron Cameras Experts
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Ric Donato
Are you a Tamron Camera Expert? Answer questions, earn points and help others
