Question about Linksys Wireless-G Broadband Router
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
Posted by prowellj on
nick campbell
    Habit-Forming:
    New Friend:
  • 21 Answers
If you want to setup your linksys router then you can go to this link, here you will get every steps for router setup .
Posted on Jun 20, 2014
  • Linksys Master
  • 7,733 Answers
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
How can I configure my - 3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
How can I configure my - 3676-003.pngc="/uploads/images/3676-003.png" alt="3676-003.png" class="h_mi" />
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
How can I configure my - 3676-004.pngb>
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 19, 2010
Need helpetting up wireless connection
WIRELESS ROUTER SECURITY
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable wireless modem. To check if the modem is configured to your ISP settings and the modem connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can get into the Internet. To connect to your wireless router, it needs the router's wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router. To set-up and secure the wireless router from unauthorized access, follow these steps: - 1, Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
How do i connect my cable to router and to cumputer
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
I have connected MSI RG54G3 to a caple and it's not give me ip and internet access
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
1. Connect the wireless router to your computer with a LAN cable.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
My Netcomm wireless on my laptop wont connect to the internet but my main computer is connected it shared thing. How can i get my laptop to read and connect to the internet?
Cannot connect to internet via wireless hub to laptop
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable modem.
To check if the modem is configured to your ISP settings and connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can connect to the Internet.
Next, the wireless router needs the wireless settings configured and then configure the wireless card in the laptop with these settings so it can communicate with the wireless router.
2answers
I have a Sony Vaio laptop and my internet (Time Warner) works when connected directly into the laptop, but will not when the cable is connected to the D-Link to the WBR-2310 router. I think it's...
reboot your modem(power it off for about 10-15 secs), reset your router. make sure your laptop is disconnected from the modem when doing this. Modem needs to catch router's ip address. Start your laptop and search wireless networks. look for your d-link router and connect. Now this is assuming you didn't firewall your router, which in tun you will need to enter your key to connect.
1helpful
No connectivity to internet
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
