SOURCE: unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
SOURCE: Changed bios setting will not let me enter setting again or boot
try boot from floppy disk if there is one floppy
SOURCE: Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
