I have a Yamaha HTR-5930 Home Theater Sys. Somehow, I've managed to lose my right channel when watching T.V. (dish network), but when my son plays with the XBox, he gets full surround stereo. Any ideas?
Re: I have a Yamaha HTR-5930 Home Theater Sys. Somehow,...
The XBox is probably hooked up separately to the amplifier, try cycling the inputs on the amplifier. If that doesn't work replace the cbale between your amplifier and tv.
Absolutely, if that doesn't do the trick, give me a holler, we will come up with something else to try!!!!Absolutely, if that doesn't do the trick, give me a holler, we will come up with something else to try!!!!
You can't post conmments that contain an email address.
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only. make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer. connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Good thinking Dan, thanks. Will let you know. Thanks again!
JC
