Question about D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router
My router is connected to my dsl service and modem all the lights on my modem are lite but i can't connect to the internet
  • D-Link Master
  • 7,733 Answers
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 19, 2010
6ya staff
SOURCE:
I have a smartrg wireless router I disconnected from all cables, relocated and hook it back up and now I have my power lite whan light my dsl and Internet light are not on and I can't connet Internet
Ensure that you have the cable from your DSL modem connected to the DSL (WAN) connector port on the rear of the modem. Also ensure that your dsl modem is connected to the phone line. If your modem is a model SR-350NE and it does not have a port labeled WAN on the rear, you must connect the dsl modem to the LAN1 port.
Here is a link that may help you.
http://www.lmi.net/wp-content/uploads/SmartRG350N.pdf
Nov 13, 2015 | Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Router won't connect me to internet
both the dsl box and the router must be configured to work with each other.
ask your internet service provider on how to turn the dsl box into a regular modem as most are hybrid modem-routers.
Mar 31, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Oct 03, 2009 | Belkin F5D8236-4 Router
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Hi and help please :)
1.       Check the for the Physical connection Between the router and dsl  the  modem
2.       And make the sure the dsl light or the status is solid green in the dsl modem
3.       If the dsl light or link light is bilking on the dsl modem . call your service provided and run a line test to confirm if there is any problem with the telephone line
Oct 16, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router Logo
70 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
