MadCatz Racing Wheel does not support devices with a USB plugged into a port specificly. This is of course if you're indeed using it. Also, some games will not support the MadCatz racing wheel directly. Many games are not designed to work with it. So check online for documentation on it.
The MC2 wheel should have a wire with several connectors on the end. One of the connectors should be identical to a PS2 controller connector. Use this instead of the controller.
My MC2 did not work at first. It is not the wheels fault! PS2 steering wheels are powered, a fuse often goes out in the PS2. Regular controllers will work, but anything powered will not.
Controller rumble requires power as well. If the rumble no longer works on the controller then the wheel will not work either.
The easiest way to do this is to go online and order a PS2 controller to PC adapter on amazon.com or some other site. I have a Madcatz MC2 and a Ps2 controller to PC adapter (a cheap one -_-") and it works okay (I'm having a lot of trouble with the pedals though).
