Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a stand fot the 46" aquos flat panel, where
TvPartsGuy.com
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Dec 10, 2011
TvPartsGuy.com
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
33084
Points
60
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Nov 19, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366142
Points
33650
Chi Chu
Level 3:
  • Sharp Master 8,457 Answers
  • Posted on Nov 18, 2010
Chi Chu
Sharp Master
Level 3:
Answers
8457
Questions
0
Helped
2820448
Points
26282
Tries websites like Ebay.com,Amazon.com to buy.The have many base stands for the LCD,Plasma tvs models.
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
1helpful
I'm needing a replacement stand for my sharp aquos model LC46LE810UN
The stand and the screws you will need for them can both be purchased at encompass parts.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEARCH&mres=1&mrpn=SHALC46LE810UN
1helpful
Missing parts for stand. Can parts be purchased?
I'd check on eBay. Many people will remove the stand and mount the TV to a wall or to a console stand. Discarding or selling the original stand. You can usually get them for far less than you'd pay for replacement parts.
Good luck,
Mark
I have a 42" sharp aquos lcd and I am trying to get the stand off so I could put the lcd on the wall. what is my step by step to make this happen. Thanks, [email protected]
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
This is the link to Sharp's manual download page.
Select "model not listed" then enter your model # and enter. Go to page 49 and it gives the diagram of how to pull the stand off and the tools needed.
Hope this helps
2helpful
2answers
I can not remove the stand from my sony aquos tv.
With the 4 long screws removed, it should come out.
Here's where you can download the manual for the LC-46D62U.
http://www.sharpusa.com/files/tel_man_LC46_52D62U.pdf
It has the instructions you need for the stand.
1helpful
2answers
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
42helpful
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
1helpful
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
