Question about Roper 24 in. RUD3000 Built-in Dishwasher
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
Posted on Nov 18, 2010
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water
completely.Such as clogged drain hose,worn belt,pump assembly,bad
motor,defective timer,drain valve etc.Please check the bellow links to read the
article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please get back to us if you have further query else please accept
the suggestion.
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
