Question about Amana ASD2622HR Side by Side Refrigerator
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: freezer won't chill beyond fridge temp
compresoor sounds like its tryin to start but cant, should be covered under 5 yr manufacture warr.
Posted on Feb 24, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Posted on Feb 19, 2009
Anonymous
  • 40 Answers
SOURCE: My Amana has been making a loud buzz for a few
Possible cause can be a small leak in the cooling circuit.Sometimes it happens especially in the welding points so you get no performance.It is better to change it with an efficient model as reparing the circuit is really a lot of work.
Posted on Jul 01, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: hi ! love my 15 yr old walkin Amana fridge freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 31, 2010
Anonymous
SOURCE: Loud buzzing/Humming noise.
Posted on Nov 18, 2010
Hi ! love my 15 yr old walkin Amana fridge freezer ,but lately its really loud for long periods then reverts to it usual sound level or absolutely silent !
heatman101
3helpful
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
1helpful
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Frigidaire side by side fridge/freezer
Try checking the evaporator fan. The blades are just pushed on and sometimes may work itself up or down and plastic fan could be rubbing.
3helpful
2helpful
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
2helpful
2answers
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Amana ASD2622HR Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
