Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
How do you change battery on E Howard wrist watch, how does bach come off?
Posted by wd4nau on
  • manny447
    manny447 Jul 15, 2012
    The model I have doesn't have a model number on it anywhere (that I can see) It is the radio controlled version. The back does come off but its tough. There are no notches. I used a really sharp pocket knife to wedge in between the back bezel edge and used the lugs (things that holds the watch band) as leverage. After a bit of finesse and force was able to pop it off and get to the battery. The mechanism is one piece on my model and is easy to put back in the case. It took a while to figure out as I was afraid to scratch it but figured it must come off some how and if a break it oh well.. it was useless to me with dead battery anyways.. went for broke and pop it came off nicely. The battery is a CR1620 although I'm sure there many different models out there with different battery sizes. Good luck!!
Overmod
    Habit-Forming:
    New Friend:
  • 20 Answers
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
[email protected]
Model number on my module is AR600 WWVB (37.5mm)
Posted on Dec 09, 2010
manny447
    New Friend:
Posted on Jul 15, 2012
How to replace battery EH-23GA
when you have an expensive watch, take it to a jeweler or, to a pawn shop. Many pawn shops change batteries, and are cheaper than jewelers. Always ask for price first.
Sep 05, 2014 | La Crosse Technology E. Howard Ambassador...
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
Does the Swiss Army Wenger Alpine 72558 Wrist Watch take a battery?
Yes, it has a Swiss Quartz movement, so a battery is what makes your watch work. Need a new battery? Take it an authorized dealer or other business that has the right tool to open the case. It's not worth ruining an expensive watch just to save a couple of dollars to change the battery.
Aug 19, 2010 | Swiss Army Wenger Alpine 72558 Wrist Watch
Had new battery installed in Howard wrist watch, cannot get the correct time. The date is correct.
You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Jul 17, 2010 | Watches
96R19 Wrist Watch: How can I change the battery...
A general observation - Take you watch to a shop to have it done professionally. Some watches are difficult to get into and there are lots of pitfalls for the unwary. I've seen far too many watches ruined by people wanting to save a bit of money by trying to change batteries themselves.
May 18, 2010 | Bulova 96R19 Wrist Watch
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
6,059 people viewed this question
Top La Crosse Watches Experts
Ekse
Thomas Perkins
Thomas Perkins
Overmod
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
