Question about Nike EV 0253 Sunglasses
I have a pair similar to the EV0253 and the rubber on the nose piece bridge has disintergrated due to interaction with sunscreen. Can I replace the nose bridge piece?
Posted by avallemann on
Anonymous
    Scholar:
  • 103 Answers
Hi
you can certainly replace your nose piece bridge by taking your cool sunglasses to the show room where you brought with the bill they have given you but you should have warrente or you need to pay for it but it wont cost much . or you can vist the site below ,for reparing your sunglass
http://eyewearus.com/pd.asp?prod_id=10918&txt_brand_id=174&cbocat=1
Posted on Dec 02, 2010
Remove gauge Zojirushi Thermal Gravity Pot dispenser
Hello there,
I just had the same problem - here comes the solution!
The device in front of me is the "Zojirushi Thermal Beverage Dispenser VYBE-25". Cleaning the gauge is really tricky - and really disgusting if your guests see the dirty gauge before getting a coffee...
Once you know how to do it, it is easy! You don't need a screwdriver or anything. The black gauge cover can be removed. It has 3 pair of noses on the backside that snap into the body (1 pair on the top, 1 pair in the middle, 1 pair at the bottom of the cover). First, squeeze the gauge cover at middle heigth, then at the same time push the cover upwards. This should release it. Only the two noses in the middle block it from being pushed up.
I attached four pictures. They also show the shape of the noses and the snap-in holes. I guess this will make you fully understand my description. You can also find the pictures at http://www.filefactory.com/file/3ff1g79vrni1/n/vybe-25_zip. ZIP-password is "zojirushi".
Once the gauge cover is removed, you can easily pull the gauge (which is a glass pipe) out of the rubber pieces.
Regards from Germany,
Johannes
Mar 15, 2013 | Zojirushi 2.5 Liter Thermal Gravity Pot...
Zojirushi VYBE-25 manual
Hello there,
Johannes
Is there anyway to tighten or slightly adjust oakley frogskins
You'll need to send it in to Oakley for the "Juliet Service". Call the 800 number and they will get you setup. Last time i had it done it was somewhere in the neighborhood of $60.00. But they redo the rubber in the nose bridge (you need a special tool), replace the nose bombs, temple shox, and ear socks. So for the price of the replacement rubber kit, you get a full service. The glasses come back feeling like new.
Jun 14, 2011 | Oakley Frogskin Sunglasses
I have a pair of Tag sunglasses. I believe the model number is 6008 102 but the full numbers that are on one temple are 115/1 30 TH 6008 102 59 1703. There is a rubber nose piece that is mounted on a...
go to the official Tag Heuer website, www.tagheuer.com, look for the retailers in your country chose the one nearest to you and contact him The name of the model is TH 6008 102
May 17, 2011 | Tag Heuer Clothing Accessories
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
Hi Today I started using the Eight Hour Cream Sun Defense for Face SPF 50 Sunscreen...my face on my nose and around my mouth area is burning and feeling sensitive...I work under intense Florescent...
Hello Dear
Stop Stop using that cream. Your skin is getting sensitive and if you do not stop using it it will cause rashes and red lines on your face. The product doesnot suits you.
Wash your face and do icing for ten mins.
hope it will work
regards
Feb 08, 2011 | Elizabeth Arden Eight Hour Cream Sun...
The rubber tube that picks up the fuel came off
What brand is a L110?
Normally a pickup tube comes from the top of the tank, and is held in place by a round rubber bushing with a steel fitting in the center. You can remove the steel fitting by pulling it out of the rubber bushing. Many manufacturers in the last 5 years have had problems with rubber lines disintegrating inside the fuel tank, and have come up with a 'special' hose to use for pickup hose. I would suggest getting the 'special' hose to replace it with, as a regular hose will work for about 2 weeks, and come off again. (due to the gasoline/achohol attacking the material of the hose and swelling, it will not stay on the fittings)
It may not be necassary to remove the tank, just use a piece of wire with a hook bent on the end to retrieve the old hose which has a weighted pickup fitting on the end. You will want to reuse the fitting.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Garden
My blender with the rubber part on top (black piece) of the motor actually disintergrated while in use. Motor is fine, just that the black rubber that fits into the glass part that makes the turning is...
call manufacturer if still under warranty they will replace most times for free if not under warranty buy part google name and model # see what that brings up! Best of Luck to you!!!
Jun 28, 2009 | Blenders
Water not getting in to dishwasher - Haier WQP12-AFM
Have you taken the supply line off of the appliance and the water line? Sometimes due to the hot water it deteriates the rubber seals that are on the valve stems and pieces and get stuck in the supply line and in turn restricks the water flow.
Take off the entire supply line and inspect both ends. If you do not see anything, then wrap a napkin around one end and blow into it and see if anything comes to the opposite end. If so, get a pair of needle nose pliers and remove the item. Good luck. Thanks.
Jan 18, 2009 | Haier Dishwashers
Nike EV 0253 Sunglasses Logo
1,477 people viewed this question
Top Nike Clothing Accessories Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Jim Pattison
Are you a Nike Clothing Accessory Expert? Answer questions, earn points and help others
