Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Nov 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Self cleaning stops after about 1 hr with error code F5E5
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Nov 18, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10835189
Points
101584
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
1helpful
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3answers
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 • Ovens
F9-1 what does this mean?
Hello there:
This error code is referring to the door lock feature and is telling you that the door lock motor may be bad or there is a problem with the wiring
If you were using the self clean feature before this happned you will have to reset the internal reset feature found on these ovens this is done by unplugging the oven and leaving it set for a minimum of 1 hr. then after this is done plug it back in and you may hear a audiable click sound if so great simply press the cancel button and it should be ok from there
But if not you will have to have the door motor inspected and any associated wiring tested for continuity and replaced if found bad
I hope this is very helpful for you
Best regards MIchael
Dec 26, 2010 • Amana Ovens
1helpful
Code F5E5 after using self cleaning on KEBC107 Kitchenaid.
Hi, f5e5 stands for clean temperature not reached after 30 minutes. You should check your door gasket, hinges and you latch to make sure the door is sealing. You can take a piece of paper like a receipt and put it in the door and pull it out with the door closed to feel for resistance on the paper. If there is no resistance on the paper then the door is not sealing. you can try hitting the stop clear button for 3-6 seconds if that does not take the error code off then turn the breaker off for about 30 min.
In some instances, this could just be a glitch and a reset could be performed:
  • Press and hold any key for 1 minute to clear R failure code from memory.
  • F2 will appear.
  • Press CANCEL and observe for 1 minute to ensure operation is correct.
5helpful
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
2answers
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
5helpful
Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
