Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Is any thing infront of the fan or vents?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Hello. I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
