Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Don't run light go from left to right on a "Jazzy
Posted by carlywilcox2 on
lennieg2000
  • 692 Answers
Carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Posted on Nov 19, 2010
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Jan 31, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
226 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Mike
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
