Question about Epson Stylus Pro 9600 InkJet Printer
I have a Epson 9600 Printer. The problem i am having, my printer works fine for a couple of days. When i let the printer set for a day, and run a nozzels check, I am missing Nozzels, I have been doing 3 or 4 Cleanings. I have cleaned the Capping station and I have also let the printer head soak on a paper towel with head cleaning fluid. I did 3 more cleanings and printed the missing Nozzel color on a 20x24 paper.I find that over time my printer colors come back and works fine. The problem i am having, is i have to do this procedure over and over and over again. Do you have any idea why my printer head is not staying clean. I was told to do 5-10 cleanings by one of your experts , I have read that if you do more than 4 cleanings the head may get clogged with ink. Can you tell me why i am having this problem.
Posted by aeriallyon on
1 Related Answer
Korede Atunrase
  • 1456 Answers
SOURCE: I have a Epson 9600
Hello
Use the printer's utility program to self-clean the printer as many as 5 to 10 times.The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times..Often this will resolve the problem.
Please check if the printers' "ink out" light is on; you must replace the ink cartridge first.
Ensure your ink catridges are properly aligned as catridges not properly aligned might be the cause of this problem
Remove the cartridge,drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged.
Posted on Nov 17, 2010
I have had my Epson R1900 since last July, and it has worked just fine for me up until a couple of months ago when it began printing with a very noticeable blue-green tint. I always use Epson 87 inks, and...
using your printer once a week makes your printer clog even if you use original cartridges i prefer using it once a day, if you dont have anything to print, just turn on your printer and it will automatically head cleaned its head
May 24, 2011 | Epson R1900 Printer
Epson RX580 has been printing fine after installing complete set of authorized genuine Epson cartridges last week. I printed 12 DVDs and switched over to printing on paper and it worked fine for a couple...
Hi there, I would simply pull the ink cartridges out completely and then put them back in. It should act as if you are putting in new cartridges and go through the install process again. I hope this works for you!
Jan 15, 2011 | Office Equipment & Supplies
Very long delay before printing starts
Hi There
This is not because of the printer this is your PC that may be at fault free some space up on your PC clean all that you not want out,
Also make sure you not got a Virus on the PC.
All the best Pineworks
Apr 30, 2010 | Epson WorkForce 600 All-In-One InkJet...
My epson c65 wont turn on at all. couple of days
Possible hardware failure, unfortunately.
Please disconnect the printer from all the devices connected to it. Plug it in directly to a working electrical outlet which means you have to bypass the surge protector. Turn it back on.
Please log on to epson.com. Go to drivers and support page and click on help me find a service center to the right of the page to find the local servicers near to your area.
May 03, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Photo R200 unrecognised cartridge message
Problem solved! I moved each cartridge up slightly to break contact and then snapped them back into place. Loaded a job up, pressed print and it started with no problem.
Jan 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
How to upload firmware to 9600
download the driver from this site
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10235&infoType=Overview
after extracting/unzipping the file it will include a pdf file on how to upload the firmware
hope this help, have a nice day!!
Apr 17, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
536 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
