Radio Communications Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need an atenna/aerial wht sort of an atenna should i buy for my cb its the MIDLAND CB RADIO MODEL 77-099 or does it not really matter wht one i go for the radio is in my car
Anonymous
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1274
Questions
0
Helped
315745
Points
3479
Hi, my name is John. Welcome to FixYa. Do not really matter, but Wilson makes a great magnet mount that perfect for the job. Not that expensive, just make sure you mount it where nothing is blocking it.....good luck and thanks for choosing FixYa...John
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance.
15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ...
8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
Midland cb keeps blowing fuses
depending on which model it is there is a reverse polarity diode near the power cord that connects the radio . If it was connected wrong no matter how many fuses you insert it will keep blowing them. You have to change that diode in order to get the radio to work. If you still have the fuse problem then take it to a tech and let him fix it.
Need manual for midland 76-858
here is the pin outs.. look at the switch in the mic handheld housing.. and attach as the one shown for midland 4 pin. this will work with any radio. and doesn't matter which color is what.. as long as the wire on the switch matches the wire on the pin correctly.
I just installed my midland 1001z and it works like half of the time. and then the other time it is just static just bought a power filter so idk if that is going to help or not any idea what else could be...
  • Hi, I can help.
  • If you rig is working part of the time and then out of the blue is "staticky" then I would suggest that you check the antenna connector on the back of your CB. Also check the connector on the coax going into the radio and also check the coax where it leaves the inside of your car and see if the outside of the coax is pinched or worn.
  • Static out of no where is a good sign somehow your antenna is failing. You could also be picking up some bad skip which will raise the needle on your CB and cause a lot of loud static out of no where.
  • Static part of the time and not others is not really a symptom of car interference (even with a hybrid) so the filter won't really serve in that aspect but it will quiet other noises so it is not a waste by any means.
  • if you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
1helpful
The wire broke off my aerial and the transmit button was pressed with no proper aerial, mended the aerial, now I get an SWR reading on my meter of 1.2 but no power output reading and no reply's to calls !!...
it sounds like u fried your final.. Its only your driver/buffer transistor that's working right now..
if u can identify them usually large square transistors close to the aerial conn,
look for # on front of transistor buy replacement and replace . if your handy with the iron it should be a cake walk.
1helpful
HI i installed a midlands 1001z in my old land rover a few days back , and have not heard any chatter or signals back from any one , when i press the mic the screen shows a full display of lights(signal) ...
Aluminum is a great conductor, and it sounds like your setup is just fine. Make sure that CB/PA switch is in the CB position. If it is, and you still don't hear any transmissions, chances are that there's just no one using this one-popular service in your area. I just tuned through through all 40 channels here in San Antonio, Texas, and didn't hear a single peep.
Bill B
2answers
New hand held Midland CB Model #75-785 that will not transmit
Try asking any onrt CB'ers if they can hear you at all.
Could be 2 things -
#1 - you are really too close.
#2 - you've blown the output stage of your rig by keying the mic without an aerial fitted.
- This is very common, and most repair centres are used to dealing with this.
If you are up to electronic repair, it's possible to DIY repair.
Could also be an antenna mismatch or fault.
2helpful
Midland 1001Z Channels
Hi yes it is possible as is anything if your willing to pay for the conversion , it would require new chrystals and resetting of the If system but is possible . However porobably not economical Midland did do The 100 model in an Fm modulation format and you will probably find still available on Ebay or Amazon if not that paticular one a good version at any rate ..I beleive they did actually do an Am Fm model also ...Regards Vortash
Midland 38 pr27/97 cb
red to (+) , black wire goes to (-) on the battery, 50 Ohm Coax cable to an aerial mounted onto a flat horizontal metal ,so that the aerial is at 90 degrees to the flat metal its monted on. Adjust the aerial size to see a SWR less that 2
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
