Question about Canon PIXMA MP600 all-In-One InkJet Printer
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the print head - is this cost affective on a soon to be 3yr old printer?
Posted by ahaddy on
Brian Lee
    Scholar:
    New Friend:
  • 110 Answers
Have a read through this relevant class action lawsuit and apply for compensation when the case settles (soon).
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Posted on Jun 24, 2015
beng8105
U Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Posted on Jul 07, 2011
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
Canon MP600 printer, error msg. U052 Cleaning the printer head doesn't help. Replacing with new (full) cartridges doesn't help. The only one thing, that helps now, is to disconnect the printer from power...
Description
Reseat the Print Head to resolve the U051 / U052 error.
Solution
Errors displayed on the printer's LCD screen:
  • U051 Print head is not installed. Install the print head.
  • U052 The type of print head is incorrect. Install the correct print head.
Reseat the Print Head:
  1. Make sure that the power is turned on, and open the Paper Output Tray gently
  2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
  3. Remove all the Ink Tanks in the following manner.
    1. Push the tab (B) and lift the ink tank to remove.
    2. Do not touch the Print Head Lock Lever (C) while removing the ink tanks.
  4. Once the ink tanks have been removed, raise the print head lock lever.
  5. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
    *Before proceeding to next step, check the carriage area for packing material, torn paper, etc. and remove if found
  6. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
  7. Insert ink tanks into the print head.
    1. Insert the front end of ink tank into the Print Head at a slant. Make sure that the position of the ink tank matches the label.
    2. Press the mark (Push) on the ink tank until the ink tank snaps firmly into place.
      Make sure that the ink lamp lights up red.
  8. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Note: When the next printing begins, the print head cleaning will begin automatically.
If you have reseated the ink tanks and print head and the error still appears, our industry-leading support team is available to help you Monday through Friday from 10 AM to 10PM EST. You can contact our technical support experts by phone or email:
Call 1-800-OK-CANON (1-800-652-2666)
May 06, 2017 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Nov 21, 2008 | Canon MP610 Photo All-In-One Printer
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
Oct 10, 2008 | Canon MP970 Photo All-In-One InkJet...
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
Code U052
It's most likely an after market cartridge. Try a diiferent one or get the OEM.
Jun 02, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
3,901 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
