Tip & How-To about Ford Escort
1999 Ford Escort firing order and ignition troubleshooting.
Refer
to the diagram. Cylinders are connected as shown on the diagram in
blue. 1 goes to cylinder 1(sparkplug furthest from coil pack), 2 to 2, 3
to 3 and 4 to 4(closets to coil pack).
To test the coil pack use a
digital volt meter. Measure resistance between coil towers for coil
1(marked 1 in red on diagram) Value should be between 12000 and 14500
ohm. Do the same for coil towers 2.
Measure resistance between I and C1. If the measurement is more than 5 ohm the coil is defective. Do the same for I to C2.
Measuring voltage at I(Ignition start/run) to ground should be 10V.
I
is connected to the 15A engine fuse. The radio interference capacitor
is connected between this line and earth at the coil. Disconnect it to
see if it cures the misfire.
C1 and C2 connect to the powertrain control module. The module earths each line to make its respective coil fire.
Bear in mind that aftermarket coil wires may cause problems with misfiring so use OEM parts where possible.
