Question about Whirlpool Duet GHW9150P Front Load Washer
I cannot use the washer. The "Control Locked"
Posted by vsaitoi01 on
Kevin White
  • Whirlpool Master
  • 1,902 Answers
Hello
Control locked means that the control is locked and needs a Reset, try pressing the END OF CYCLE button and hold it for 15 seconds to solve the problem. Please get back to me if you have any other questions.
Kevin
Posted on Nov 17, 2010
Mike Price
    President:
  • 744 Answers
Hit the end cycle button for 3-5 seconds. Until the control unlocks.
Any further questions please fee free to ask.
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
The light for "Control Locked" is on and will not
have you pressed cancel for 3 seconds or more? otherwise press for 3 seconds control-lock and see if it releases
Mar 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
"Control locked" light is on. Machine will not
Press and hold the button thats says control lock//that will unlock or lock the control panal...If it helped please vote need more help please ask good luck
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
unplug the washer,remove the lower panel, get hand under the front panel on right side and pull a level while pulling the door open. put back together the lower panel.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Light reads "control locked" and washer won't work
Please Turn On your washer and hold the END OF CYCLE button for about 10 seconds and that would surely unlock your washer.
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 26, 2010 | Whirlpool Washing Machines
The "control locked" light is
Press and hold the end of cycle signal-button for 3 seconds and it is ready to go.
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My "Control Locked" is locked. What do I do?
Select and hold the end of cycle button for 3 seconds until the control locked status light goes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
