My WHD928 won't start. Plugged in, tank is in correctly- but no go. The lights don't even come on. Is it terminal??
I hope it's not terminal, as Windchaser is no longer in business. Remove and check the top of the water collection bucket for a float valve. It may be stuck in the "UP" position. If it is, jiggle the arm to make it return to the "Down". While you have the bucket out, look inside the bucket holder. On the rear wall of the holder you should see the bucket removal safety switch. It should look like a plastic trigger switch. With the unit ON, activate the switch with your finger. If the unit does not turn ON, then the switch is at fault. If it turns ON, then the bucket was not making contact with it, when it was last reinstalled. Reinstall the bucket "squarely" from top to bottom into it's holder. Making sure that it does not tilt down at the bottom when installed and makes contact with the switch.
If the unit did not turn On when you tried to activate the Bucket Removal Safety Switch, it's time to start shopping for a new dehumidifier. As there are no parts available for Windchaser units.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
