With the printer on but not busy (flashing light), open the scanner unit. (Lift the scanner until the bracket on the right locks.)
If the cartridges are completely expended:
Press the Stop button on the printer, the print head should move to line the expended cartridge with the empty ink mark. Press Stop again and the next empty cartridge should line up with the mark. Continue to press Stop until the print head moves to the cartridge replacement location (after noting which cartridges need to be replaced).
One cartridge at a time, shake the new cartridge 5 times before opening the package.
Remove the new cartridge from the packaging and remove the yellow tape from the cartridge. Be careful not to damage the hooks on the side of the cartridge and do not touch the green IC chip. Leave the transparent seal in place.
Squeeze the tab at the back of the cartridge you want to replace and then lift the cartridge up. Then put the new cartridge straight into that slot and press down until it clicks.
Repeat this for all empty cartridges. Then close the scanner unit and press Stop. Wait until the light stops flashing and the empty ink error light goes out. The unit will charge the ink system while the light is flashing.
If the empty ink remains flashing or is on with the print head in the home position, then a cartridge may not be properly inserted. Press Stop and then push down on the cartridges. See
http://support2.epson.net/manuals/english/spc/stylustx100tx101/guide/html/ink_4.htm for pictures and images.
If the ink isn't expended, use the Ink Replacement utility in the Epson software. For Windows, this is part of Printing Preferences in the Maintenance tab. Open the Devices and Printers (slightly different name in older versions of Windows) control panel. Then right click on the printer and choose Printing Preferences.
I hope this helps.
