Question about Necchi 3101 Mechanical Sewing Machine
If you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Posted on Nov 17, 2010
SOURCE: Where to find Necchi 525FA sewing machine bobbin
Your Necchi uses a generic 15 Class zig zag bobbin case. Jo-Ann Fabrics sells one for White machines that will work for under $5.
Posted on Feb 15, 2011
Jun 18, 2018 | Necchi Sewing Machines
Mar 03, 2018 | Necchi Sewing Machines
Feb 03, 2018 | Necchi Sewing Machines
Mar 23, 2015 | Necchi Sewing Machines
Jan 21, 2013 | Necchi Sewing Machines
Sep 14, 2012 | Necchi 4575 Mechanical Sewing Machine
Apr 08, 2012 | Necchi Sewing Machines
Nov 21, 2010 | Necchi Sewing Machines
May 31, 2010 | Sewing Machines
Nov 01, 2007 | Necchi 3101 Mechanical Sewing Machine
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
424 people viewed this question
