My remote control for my 52" Hampton Bay "Moresby" ceiling fan is on the fritz...I replaced the battery...however, the fan changes speed, changes direction (reverses), and cannot be turned off with the remote control...it has run amok...can I get a replacement remote??? or can mine be fixed???
Recommend you try contacting Home Depot directly.
Depending on age of the fan, you may be able to order replacement part. https://www.homedepot.com/c/customer_service
Hampton Bay is a Home Depot brand name. Most (not all) have a lifetime warranty. I think that if you take it to the nearest HOME DEPOT store, WITH the receipt they will help you by fixing or replacing the remote.
We have our home completely covered by HAMPTON BAY fans and one went out after several years and they replaced it no charge for another fan.
We have had great success with HOME DEPOT products and shop there often. Our preferred store is the one in Mesquite, TX on I635 East.
SOURCE: How to reverse ceiling fan for cold weather
Thank you for your response. After I posted ? a button was discovered. Problem solved! I did add this to my ? box yesterday.
SOURCE: Two ceiling fans, both remotes control the same fan
One of the dip switches is located under the globe, near the ceiling.
The other dip switch is located in the remote control. You have to take the battery out and look in the space where the battery is, usually towards the top of the remote.
On mine, there are four settings, the dip switches have to be in the same position, on both your remote and the fan unit, for them to work. You might have to reset them if you do not want both fans to work from one remote. Maybe one fan and remote have the first switch up and the other three down, that would let them both connect. The other may have the first one down and the others up, then it would only work from the remote that is set the same way.
Usually you can reset them by using the point of a pencil to move each dip switch setting.
SOURCE: Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
every ceiling fan we have in the house is operated by remote control...one remote will operate all fans. we have been on vacation, came home, turn the fans on and the top light to every fan goes off and on by itself and the bottom light either was on to start with or it won't turn on at all.
three of the fans are hampton bays and the other ones are hunters. this is every fan in every room. what could be wrong????? HELP!!!!!
thanks for any help.
mindy
i have 2 hampton bay remote controls and they do not work.
i bought them at home depot. one is M2 and the other is U2. i need a replacement.
pam ricketts
EXACT SAME PROBLEM
