Dacor ECS127 Epicure Electric Single Oven Logo
Posted on Sep 07, 2017
I have a 10 year old dacor oven model ERSD30 and usually if we have a problem with the clock blinking or a failure code we turn off the breaker and turn it on again to reset., but now the clock isn't keeping proper time, tried to reset with the breaker off and on several times without luck. the clock displays time but its running too fast to be accurate. Please advise
4 Related Answers
Anonymous
  • Posted on Oct 08, 2007
SOURCE: Possessed Oven
I found a new touch panel (or membrane switch pad) for < $166 at http://www.myapplianceparts.com/ . The person on the phone at this company was very pleasant and immediatley confirmed that they had 10 of these in stock. This suggests to me that more than a few of these have gone bad. Luckily, they are very simple to replace if you are willing to turn a few screws and carefully pull of the electrical connectors. I dissasembled mine in 20 minutes, got the part number (#62682B for my ECS130), and found best price in 20 minutes.
Anonymous
  • Posted on Feb 24, 2008
SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Anonymous
  • Posted on Oct 10, 2008
SOURCE: Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Anonymous
  • 1157 Answers
  • Posted on May 18, 2011
SOURCE: dacor model ersd30 how do i fix an F0 error code
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
Hope it helps.
The time blinks at 12:00, there is a beeping sound, the oven does not work. It's only 2 years old.
Hi.
The beeping sound is a warning because the oven is in lock condition, or because a fault had been detected. In this last case there would be an error code or something unusual.
Push and hold the Clock button for about 10 seconds, that will reset the oven. If that does not work, then trip the circuit breaker for five minutes and hold the button again to reset.
If still no luck, then there may be a fault condition. In that case better calling the Frigidare number listed on the owners manual.
If the oven is two year old , then there may still be warranty cover on parts, one more reason to contact the manufacturer if the oven does not reset.
Try resetting the oven first.
Regards.
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 • Ovens
Is there a reset switch for Decor Electric oven? Kids turned on self clean and read out stopped working. Unit is at least 10 years old.
You can reset the oven by shutting down the breaker for the unit for an hour or 2, if your oven is over ten years old it might not help, the board could have been fried, good luck
Jul 15, 2009 • Dacor Ovens
1helpful
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
1helpful
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 • Ovens
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
4helpful
2answers
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Oven not working
15
problem
8. door will not open.
9. oven will not heat after Self cleaning.
possible Cause
oven is in Self-clean mode.
time of day is not set due to power failure.
oven settings are not correct.
remedy
if oven is hot, door latch will release
automatically when oven temperature
falls below 390˚F at end of cycle.
if Self-clean was just selected
and the oven is still cool, press
“caNceL•SecuRe” to turn off Selfclean.
the door will open in about 30
seconds.
Press “cLock” touch pad, then press
“tiMe•teMP” pad to set correct time of
day.
follow mode selection and clock settings
as specified in the oveN oPeRatioN
section.
oven will turn on automatically
at preset time. if desired, press
“caNceL•SecuRe” touch pad to cancel
out of delay timed mode.
Troubleshooting Guide (Continued)
Important:
If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
after a failure. Call a qualified appliance technician to repair the oven.
Oven Failure Codes
Clock Display Cause
f0. touch pad is stuck in depressed position.
f1. Relay circuit failure.
f . oven temperature exceeded the clean runaway temperature (Self-clean mode
only) or the cooking runaway temperature (cooking modes only).
f3. Short circuit in the oven temperature sensor.
f4. open circuit in the oven temperature sensor.
f6. failure in the eePRoM check comparison. (only time of day and timer will
operate.)
f7 failure of the Self-clean automatic door latch circuit.
f8. failure of the door latch motor. occurs when the motor runs for two minutes
without the door locking in Self-clean mode.
befOre yOU Call fOr servICe
No maintenance, other than the Care anD CleanInG
InstruCtIons identified in this use & Care manual, should
be attempted by the owner/operator. all other maintenance and
service must be performed by a qualified appliance technician.
first, review the recommended checks listed in the preceding
troubleshooting Guide. then, be certain that the appliance has
been installed properly and is being operated correctly. familiarize
yourself with the warranty terms and conditions listed in the
proDuCt WarrantY section.
if the above checks have been completed and the problem has
not yet been remedied, call your local authorized dacoR®
service representative. your dealer can normally provide the name
and telephone number of the nearest service company.
prOdUCT maInTenanCe
If yOU need servICe...
dacoR® works diligently to ensure your satisfaction when
service is necessary. However, if you are not completely satisfied
with the service provided, contact the company that performed the
service and express why you are not pleased. Normally, they will
be willing and able to resolve the problem.
if the service agency is not able to respond effectively, call or
write the dacoR® customer Service department. the phone
number and address of this department are listed on the inside
front cover of this manual. Please include your telephone number
if you choose to write. we will then do our utmost to assure your
happiness and satisfaction.
Here is a snipet from www.dacor.com
You can view the manual there by enter ing your oven model number.
2answers
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
