Pioneer VSX-607 Receiver Logo
Posted on Nov 17, 2010
I need the remote code for a pioneer vsx502 receiver for att uverse remote
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
840
Points
I used 5120 to turn off and on the receiver on the Aux button, I am also control the volume on the recevied by assigning the volume control using 955 code. The one thing I lack is a way to change the receiver input between BD, HDMI1, HDMI2, etc. I still have to go to the Receiver remote for that. I know the Uverse Receiver can't do everything, but if I could just get the input to change on the UVerse Remote, it would be awesome. I'm trying to avoid getting a Harmony. The blu-ray and tv also work, which is great! See this reference for the silver remote:
http://www.att.com/support_media/images/pdf/uverse/remote_control_user_guide.pdf
If you have black, you may need to visit the AT&T support site to get the black manual.
1 Related Answer
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on May 22, 2009
SOURCE: Anyone have the remote control code number for the Pioneer VSX515 receiver?
Are you trying to progam another remote to control your Pioneer? If so, check with www.remotecentral.com if it's available, it's there!! Hope this helps
2answers
How to program my remote control for my TV to run my Pioneer receiver
Use any option you are not using on the,TV remote. Go to the pioneer web site and find your model receiver and then find the codes that work for it. Try each code with the receiver on. After entering a code hit the power button. When the receiver turns off your all set
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
I need a daewoo tv remote code for att uverse
0029,0022,0025,0021. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
1helpful
2answers
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
2helpful
My att remote control for my uverse did not come with a manuel
Here is the manual for the remote and the codes are there also.
http://helpme.att.net/pdf/uverse/remote_control_user_guide.pdf
Good luck and Please rate FixYa!
2answers
Att uverse remote won't turn on yamaha reciever
Yamaha Receiver/Amplifier 5003, 5014, 5015, 5021, 5102, 5103, 5104, 5105, 5106, 5118, 5135you can use those codes
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
