This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
over dose of detergent detectd during the wsh cycle ////// the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor . if "sud" is displayed a potential suds lock is detected . this may signify a badpump an extra heavy load excessive detergent or excessive suds.................
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Suds. Suds is caused by not using HE detergent OR too much detergent. Remove the service panel below and you will find a jacket with a list of errors and suggested remedy's. SERVICE MANUAL DUET SPORT
5D actually means suds, make sure you aren't using normal detergant as
these units require 'HE or High Efficiency' detergant that doesn't suds
much. Try runing a load with not clothes and just put in a cup of
white vinegar to remove all the suds in the machine and see if goes
through spin with no suds in. If not and you still get an error you
will need to replace the pressure switch because it thinks there is
water or suds in the machine it's not removing.
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
run washer with no load or detergent to be sure no suds remain use HE detergent only..if you are suds is not an issue remove lower panel and clean pump ..turn white knob counter clockwise ..electronics can get confused sometimes too
