Question about Black & Decker 750w Power Inverter
I blew a fuse. How do i get at it? I cant even see it
Posted by alicecooper3 on
Anonymous
    Scholar:
  • 72 Answers
Hi, you need to remove the cover of the unit and inspect the three 40 amp fuses inside. They are the blade type similar to the ones found in automobiles. Hope this helps
Posted on Nov 17, 2010
If i remove my dash clock can it affect my alternator
yes, and yes, you blew fuses ,
the alterator does use a sense line to dash IGN terminals.
forget that. you failed FSM rule one, disconnect battery neg terminal before doing electrical repairs.
test all fuses, no car, no year, no model stated, so cant show which fuse. 12vdc on boths sides of all fuses, key on, is GOOD.
fuse that look good can be bad.
you shorted out clock wires and blew fuses
easy peasy , prob.
Jan 18, 2015 | Cars & Trucks
Battery placed in backwards
You probably blew a main fuse or circuit breaker. I believe your fuse box is on the driver side under the hood. Check your owners manual for fuse I.D. Then check the main fuses.
Apr 21, 2014 | 1995 Toyota Camry
I changed to led lights all round blew a fuse replaced it now front 1s work but back lights dont
Check fuses again. Usually headlight and tail light fuses are on a different circuit so have individual fuse for headlights and tail lights.
Jan 30, 2018 | 2004 Suzuki GSX 1300 R Hayabusa
Have a 2001 v star 1100 was riding down the road and died found it blew a 30 amp fuse replaced it then blew again even with the key off it still blows the fuse
trace the wiring that the fuse is for. It is likely that one has rubbed down to the bare wire and is shorting out the fuse
Oct 03, 2011 | 2001 Yamaha V Star 1100 Classic
Having taken the xmas decorations down i moved the telly stand so that we could clean around the back unfortunately my wife accidently knocked the telly and everything went off it even blew the main fuse...
Blowing your fuse means you have a short circuit my friend. Even you replaced the fuse again and again it will do the same thing unless you isolated the problem. Blewing your fuse happened because it is a guard to avoid further damaged to you and your property. If you haven't a fuse fire will occured in the blink of an eye (thanks for the fuse) This is quit technical so I've advice you to look for a qualified electrician to isolate the cause of short circuit.
Jan 04, 2011 | Televison & Video
In trying to move a 1993 sl2 saturn that had been sitting for a while, the engine started but then when the car was placed in drive, a fuse blew and now nothing works. Where is this fuse located and are...
There are two fuse boxes in these cars one behind a plastic plate down by the passengers feet and one under the hood. Which fuse blew? What is your reasoning for believing you blew a fuse? Were there any issues with the car leading up to this even?
Oct 20, 2010 | 1993 Saturn SL2
Igniton fuse continuously blows on my 1995-96 dodge neon
Do you have an aftermarket stereo installed? Well, try this. Remove the ground cable from the battery. Install a new fuse. if it continues, Remove the center console. and check the reverse wire connected to the shifter. It did the same thing to me and all it was, was that wire was touching other wires
Jan 11, 2009 | 1995 Dodge Neon
I blew a fuse for the front cigarette lighter hookingb up a radio where is the fuse for the lighter
a bad fuse ...keep looking .....otherwise the main acc power/ or ground to all those dash areas has been cut or compromised...retrace your steps backwards
Nov 05, 2008 | 1992 Pontiac Bonneville
Black & Decker 750w Power Inverter Logo
194 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
