SOURCE: Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably
have to buy a new coffee maker if one of these problems disables your
machine.
Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
SOURCE: My Keurig one-cup coffee maker
There is a post on descaling already but I think the unit just doesn't have enough water in the resevoir. See several of my other posts on how to fill the machine.
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
SOURCE: Coffee maker when filling coffee
Sorry to read about your problem, I hope this helps you out.
If your brewer is not brewing the full amount selected, it may be caused by the following:
* The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
* The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
* The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
If this does not work you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
