Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
Chi Chu
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Posted on Nov 16, 2010
1helpful
Have a wd60638 changed the lamp because old one busted now the TV works fine for about 3-5 minutes starts to hum and a clicking sound and pictures begins to flicker with colors going in and out
normally no bulb will bust ever unless you have oil on the lamp. sooo , it got too hot then. even if the fans turning its not putting out.
check the exhaust it should blow a lot of air past the lamp.
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Multiple vertical color lines,i take the picture,how can i send you this photo?
There are two ways you can do this.
1. post the image to a site like photo bucket or flicker and post the link here
2. next to the You Tube on the top of the post reply window click the image. This will open a window. Browse to where you have the image saved and click it. This will insert the image to your reply.
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
2answers
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
1helpful
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
2answers
Samsung HLN617W1
this just happened to me and it was the color wheel it shattered
Screen goes blank after 5-6 minutes but sound continues
It may be overheating, check fans and or obstructions of the vents
 Grubhead
Grubhead
