Their are three small screws at the bottom of the panel (FLOOR LEVEL) once these are removed you can pull out on the bottom of the panel to remove..Then you can place a shallow pan under the drain pump then remove the cap and strainer to clean......
I did the same thing but after I placed the panel back on my washer won't turn on?
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
