Question about Broderbund PrintMaster Platinum 18 for PC
Would like to order Printmaster 18.1, compatible with Windows 7 but as I live in Australia I am unable to order online as your orderform does not cater for sahipping to my country. I have used Printmaster for many years but with the purchase of a new computer I need to update my programe, Helen James
Posted by hmjames on
Michael Allan Fernandez
  • 304 Answers
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
Having compatability problems installing
Hi, PrintMaster is known for having versions that are not compatible with certain Windows Operating Systems, 18 is known to not work with Vista, yet works with 7 and XP quite well. The best solution would be either to upgrade to Windows 7 or get another version. Good luck!
Jan 10, 2016 | Broderbund PrintMaster Gold Version 18
Unable to download from disc Printmaster v.18.1 despite being led to believe its compatible with Windows 8
Printmaster 18.1 is not really compatible with Windows 8. Here's a link to a possible solution directly from Broderbund. You can try it, but you might be out of luck.
Printmaster 18 1 Platinum
Feb 28, 2014 | Mindscape PrintMaster Premier 7.0
Have old printmaster platinum 8.0 tried to download on new comp windows 7 it says something about 16 bits
Printmaster platinum 8.0 is rather an old 16bits software and it is not compatible to your new version Win 7 OS.
You can check software compatibility @ Windows 7 Compatibility Center
Your option is to upgrade to version 18 which is Win 7 compatible.
Hope it helps.
Feb 20, 2011 | Computers & Internet
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Can printmaster gold 18 be run on windows 7
Broderbund PrintMaster Gold Version 18 is not compatible with Win 7.
The Printmaster Platinum 18.1 is compatible.
Dec 19, 2010 | Broderbund PrintMaster Gold Version 18
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
I bought a new computer with Windows 7. Is Printmaster 18 compatible? I have started to install it but a message came up stating there were 'compatibility issues' Is this correct and if so, what can I do?
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Jan 10, 2010 | Broderbund PrintMaster Platinum Version 18
Broderbund PrintMaster Platinum 18 for PC Logo
178 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
