Question about Sharp Wizard OZ-630
Data was erroneously deleted from Sharp Wizard organizer OZ-650 when changing the batteries. According to the maual, when changing the batteries, we should not have wsaid YES to the 2nd question which asked about deleting data. We have no software for this. 1. Are we able to restore the data and if so, how? 2. If we need the docking station and connections, how can this be obtained.
Posted by yesdog0708 on
5 Related Answers
Anonymous
SOURCE: SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, [email protected]
Posted on Jul 22, 2007
Anonymous
SOURCE: Sharp Wizard OZ-730 docking module
Found it here -
http://underwooddistributing.com/Sharp/sharpyooz.html
but it's $49.95! I have to keep looking around the house.
Posted on Dec 26, 2007
Charles Klaus
  • 10 Answers
SOURCE: Sharp Wizard OZ-770 working with Windows Vista
The www.wizardshop.net
can help you get it working with vista 32bit.
Go to www.thewizardshop.net and email or call them.
Posted on Mar 03, 2009
Anonymous
SOURCE: Replace battery in Sharp OZ-8000 pda.
unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
Posted on Jul 18, 2009
Anonymous
SOURCE: Syncronizing the data from a Sharp OZ-650 to a new computer
Just get a USB-to-Serial adapter and use the same method you used to use. Here's the one I ordered and it works fine. It includes a CD for loading a driver which I loaded before plugging anything in.
http://sewelldirect.com/usbtoserial.asp
Posted on Sep 14, 2009
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Sharp Wizard OZ-730
How do I back up my Sharp OZ 570
i change new Batteries and then not appear anythint on Screen. pls help.
Sep 24, 2009 | Sharp Wizard OZ-730
Apr 11, 2009 | Sharp Wizard OZ-800
Retrieve Password without losing data with Sharp Organizer
According to the YO-370 Operation Manual:
What To Do If You Forgot The Password -
When you have forgotten the passord for the SECRET function, you have to delete the password along with all secret data by selecting "DATA DELETION" from the Function menu. Once the password is deleted, a new password can be entered. Follow the procedure below to delete the password (and the secret data along with it).
1. Recall the Function menu (2nd, FUNCTION)
2. Select "3 DATA DELETION", and press v (3, v)
3. Select "3 SECRET DATA". (3)
The delete prompt "DELETE ? Y/N" appears
4. Press Y (To retain the data, press N)
When Y is pressed, both the password and the secret data are deleted, and the initial display for the previous mode in use will reappear on the display.
Mar 23, 2009 | Sharp Wizard OZ-800
A quick and dirty method of getting your data to near flat file format is to find a computer with the old RS-232 serial port and use a third party software called "Rupplynx" v 6.0 or 6.1 to download the data from the Wizard to the Rupplynx software on the PC. The backup/extracted files that you create with this software will be binary but the address book, memo etc data portion of the file will be ASCII text that is readable (beware, even the secret entries are readable so you will have to guard the computer that the files are on). A better but slower way is to copy and paste the uploaded and displayed data text in the Rupplynx 3rd party software to a Word document or plain *.txt file. I did this for the most important data since I also had about 10 years worth of memos and contacts.
I copied the whole subdirectory with the binary files from a windows XP computer that had an RS-232 port to a Windows vista computer and the program ran fine so that I could get the data into a compatible format such as Word or plain text file format. (via copy and paste) Rupplynx also has an export option to export to different file formats...
Oct 24, 2008 | Sharp Wizard OZ-650PC
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Dec 25, 2007 | Sharp Wizard OZ-730
Sharp wizard oz-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
Oct 10, 2007 | Sharp Wizard OZ-730
Can you reset the passcode onSharp OZ-650PC?
Just use the menu key and delete secret data..this erases the password and keeps all other data.
Nov 27, 2006 | Sharp Wizard OZ-650PC
Sharp Wizard OZ-630 Logo
54 people viewed this question
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Robert Rankin
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
