There are two ways to get there,...
1. click on the "Start" button,
There should be an option that says "Printers and Faxes", click on it.
This should pull up a window that has your printer listed, click ONCE on your printer (to highlight it) and on the left hand side of the window under the heading "Printer Tasks" there is an option called "select printing preferences", click on it.
This should bring up another window with multiple tabs at the top. Click on the "Services" tab, then click on the "Service This Device" button. Another window will open with the following options, "Calibrate the Device", "Clean the Printer Cartridges", and "Print Test Page".
Just click on the "Calibrate the Device" button and follow the prompts.
2. The other way to get get there is to try and print something. When the window opens to allow you to change the quantity and such, click on the "Preferences" button. It should be near the top next on the right, next to the place where you choose your printer. Clicking this button will open the window with the multiple tabs that I mentioned earlier. You'll then click on the "Services" tab, then the "service this device" button, followed by the "calibrate the device" button.
Hope this helps! :)
