HP PHOTOSMART PLUS B209A All-In-One Printer Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Howo i clean print heads hp b209 - HP PHOTOSMART PLUS B209A All-In-One Printer
ONE-Touch-Solution
Level 3:
  • HP Master 1,679 Answers
  • Posted on Nov 16, 2010
ONE-Touch-Solution
HP Master
Level 3:
Answers
1679
Questions
Helped
404693
Points
5442
Are you getting the error " Printhead problem ' or 'Printhead appears to be missing or damaged " on the printer screen ?
If so, there are few steps to be followed to resolve the issue. I cannot mention the troubleshooting steps with images for Issue, so please click on the link given below to resolve.
Do this step before you follow the steps given in the link and check if this resolve's the issue.
On the Printer SCreen
Press the Setup button
Choose Tools
Choose Clean Printhead
Let the printer go through the process of cleaning.
If the above steps does not fix, click on the link below
Printhead Problem link
Thank you for contacting FixYa
* Please rate this solution with thumbs up and comments
How to clean Genuine HP 564 Printhead
Printer heads can get clogged if the printers have not been used in awhile or a print cartridge has been empty or stored for a long time. Clogs in print heads can cause problems with the print job quality. This article will tell you how to clean print heads.
I share a link please visit and read it.
http://www.wikihow.com/Clean-Print-Heads
Thanks,
HP Printer Support
I lost my printing cd to a photosmart b209 and do not want to order a new one (CANT USE THE PRINTER)
Go to hp.com and enter your printer model and select the OS you are using, then the software that you need.
Ok i bought an HP Photosmart B209 but how can i scan a picture into my computer?
You can use the program that comes with the printer. Its called HP Solution Center. There you can view your printers status, etc.. In addition you can choose to copy, scan or print files.
1helpful
Does the HP Photosmart B209 print on CD's?
No it does not. The best you can do is to print CD labels, but you would need a program with software to handle them.
Reference Photosmart B209 Manual
Thanks for using Fixya.
PS. The manual is a large file (13MB) so be patient if you download it..
5helpful
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
How do I set photosmart B209 to enlarge copies?
http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
Another option it to scan the item to the computer then print and enlarge during the print process
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
k24674
Grand Canyon Tech
Grand Canyon Tech
