Question about JVC Everio GZ-MG20 Camcorder
Broken screen on my camcorder/ can it be fixed?
Posted by newsooz on
Rick J Riggins
    Genius:
  • 1,812 Answers
Yes. The screen can be replaced and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 16, 2010
My camera shows a black (blank) screen in the preview. Any ideas on what is wrong with it?
hatachi camcorder dz-gx3100e blank screen wont power up is it reapairable as i have a holiday disc unable to eject
Mar 15, 2012 | Hitachi DZ-GX3100E DVD Camcorder
My sony dcr hc21 touch screen is not working, I went to a tech today and they chage very expensive. Is there anyway I can fix the problem ?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
  • Please make sure that you're using fully charged batteries.
  • Turn off the Camcorder and turn ON again and check the operation.
  • Try resetting the Camcorder by pressing the reset button behind the LCD panel.
  • If the issue persists again, please perform LCD screen Calibration and check if that helps. Please follow the steps below to perform the LCD Calibration.
  • Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
  • If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder. If you require any clarification or any help, please let me know. Thanks for understanding.
Apr 01, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-SR40 Camcorder broken LCD flex-wire.
Take it for a service - cost will depend on the amount of work needed.
Sep 12, 2017 | Sony Handycam DCR-SR40 Camcorder
How much would it cost to fix my flip video cause
how much would it cost to fix my flip video cause it has a broken screen but still works
Dec 23, 2009 | Pure Digital Flip Video Flash Media...
Panasonic sdr-s7 camcorder broken lcd panel
how can i help you?better ask the nearest panasonic service
Oct 11, 2009 | Panasonic SDR-S7K Flash Media Camcorder
The touch screen on my Sony DCR-HC40E is not working
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
When I switch on my DCR-HC21E Mini DV there's nothing on the LCD. Just blank. No lights nothing. So I can't use the touch screen menu. Can I fix it myslef ?
Do you hear start up (ding) soundin camcorder? does it eject tape?
If yes, then flexible connecting wire between lcd board and camcorder board is cracked/ broken and need to be replaced.
If you can apart camcorder and have little experience in electronics stuff repair, I can provide you part number of that flexible wire info.
Sep 24, 2009 | Sony DCR-HC21E Mini DV Digital Camcorder
No picture on LCD screen
Flex wire connecting LCD to the camcorder is broken. I bought it in the repair shop and did it by miself. it's very common problem
Good luck
Meggita
Aug 25, 2009 | Samsung Compact MiniDV Digital Camcorder
I barely use my camcorder as it has been broken since the second use. The lcd screen shows a "jumping" picture so you can't see what you are recording. The recording comes out correctly.
If it is still under warranty, you must mail it to the factory to be fixed or replaced. If you just want to keep it the way it is (broken screen) , you must use the small view-finder to aim the camera properly while shooting movies.
Also if you need a battery alternative that will save you money, a external battery pack can be made that will give you several more hours of recording time.
Here is the link to the battery pack video:
http://www.youtube.com/watch?v=oGMGcBECEeM
Your Welcome!
Jul 12, 2009 | Sony Handycam DCR-SR62 Camcorder
Broken lcd screen on my sony dcr-sr45
LCD view screen consist of 2 pieces of cabinet and LCD screen including circuit board inside.
Do you need LCD cabinet only or require LCD screen too?
Dec 02, 2008 | Sony Handycam® DCRSR45 HDD Camcorder
JVC Everio GZ-MG20 Camcorder Logo
97 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
