CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes
To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE
IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE
RUNS.============
For
your help there are few relatively help links showing how to remove and install
starter with proper instructions:-----
These
help links will help.
Click
the link below:-----
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn
SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
• Oldsmobile
starter solenoid replacement procedure?...
• How
to replace Oldsmobile starter moor?
• Oldsmobile
starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These
details will help.
Thanks.
HEATER BLOWER MOTOR
Its
faulty blower motor resistor. The low and medium speed on blower motor is
controlled by resistor and its actual speed is high. So because resistor is not
working, blower motors actual speed which is high is working.
It
can be faulty blower motor or faulty blower motor resistor. Get the blower
motor inspected. If it's faulty it has to be replaced.
For
blower motor testing and replacing, check the link below: ----
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
