Hello chicagogunn,
Welcome,
You said,Your unit stopped working mid-cycle. You have verified that there is power to
unit. Is there an internal fuse which could have been tripped? None of
the lights on the control panel currently light.
There is a
thermal fuse!
Go to this repair web site I listed below and you will see the diagram
1. Diagram Page 02 - CONTROL PANEL PARTS 2. The thermal fuse is, Item # 6 on the diagram.
3. Click on page two on the left at this site.
4. And then in the upper right corner it says
Open This Diagram in a New Windowhttp://www.pcappliancerepair.com/model-display.php
6
8193762
Fuse, Thermal Electronic
In-Stock
$ 13.25
Let me know how you do!!
Huuum
Please remember to leave a rating!!!!
ALSO:
Here are four things that the repair manual says to check.
1.Burnt or broken wiresCheck for burnt or
broken wires. This would include the wires on the timer and door
switch. Also check the wiring connection where the main power connects
to the machine.
2. Defective Timer
The timer is a series of
switches that controls all machine functions. If one of the contacts in
the timer is defective, the machine will lose that function. knowledge
of the the use of a volt /ohmmeter is essential to testing the timer as
well as the ability to read the timer sequence chart that is supplied
with the machine. In most cases this requires a professional technician
3.Door switchThe door switch is wired
in series with all components on the machine. If the door switch is
defective, the machine will do nothing. Check the door switch for
continuity
4.No Electrical powerEnsure that the proper
voltage is being supplied to the appliance. Check the breakers or fuses
that are supplying the power to the appliance electrical outlet. You
can use a voltmeter to test for voltage at the electrical outlet.
Thank you Huuum
