SOURCE: I need set up instructions for a wr50m 1440 sports watch
Visit www.timex.com/ - 12k - Cached - Similar pages
Choose: SPORTS, then SPORTS1440 and download manual.
SOURCE: i purchased wr50m watched i donot lnow how to set time both digit
Check out my tips and tricks here in FixYa and you will get manual for your watch.
SOURCE: I lost the setting
Here's the manual from my Cardinal NiteLite watch.
Instruction manual for Cardinal nightlight watch with four buttons.
Button one is labeled "S1" and is in the one o'clock position on the watch.
Button two is labeled "S2" and is in the four o'clock position on the watch.
Button three is labeled "S3" and is at the eight o'clock position on the watch.
Button four is labeled "light" and is in position 10 o'clock on the watch.
FEATURES
1. Normal time mode: hours/minutes/seconds/day of the week.
2. Nine then date: the pressing and holding as one. Month/date or date/month reading optional by depressing as two.
3. Alarm/hourly chime mode: depressing and will holding S2 to display alarm time. The alarm symbol and chime symbol or alternatively on or off by depressing as one simultaneously. While in normal time mode if the chime symbol or alarm symbol appears, it means that the chime or alarm is on.
4. Chronograph mold: depressing button S3 minutes/seconds/1/100 seconds (when using less than 30 or 40 minutes option) or hours/minutes/seconds (when using greater than 30 or 40 minutes option).
5. 24/12 hour format switch option: depressing as to to display alarm time in the depressing S3 simultaneously can select 12 or 24 hour format. A equals a.m., P. equals PM.
6. Sound demonstration: depressing and holding both S1, and S2 simultaneously.
HOW TO SET ALARM TIME
7. Button S1 is to select function and S2 to advance the counter.
8. Alarm hours: depressing and holding S. 30 for 2 seconds will change to set a mood. The alarm set flag starts flashing, and the alarm hours Depress S2 to advance.
9. Alerts: depressing as one causes the alarm minutes to start flashing. Use S2 to advance. Depress S3 once to return to normal time mode.
HOW TO SET NORMAL TIME
1. seconds: depress and hold S3 for 2 seconds to enter the time change setting mode. The alarm set flag starts flashing and the alarm hours start flashing. Depress S3 once to start the alarm seconds flashing. When S2 is depressed, the seconds turn 200 (when less than 30 seconds) or the minutes advance by one and the seconds start counting from 00 (when greater than 30 seconds).
2. Minutes: depress button S1, minutes start flashing. Use button S2 to advance.
3. Hours: depress button S1 again, hours start flashing.
4. Month: depress button s1 again, month Use button S2 to advance.
5. Date: depress button s1 again, date starts flashing use button s2 to advance.
6. Day of week: depress button s1 again, the day of week starts flashing. Use button s2 to advance.
7. Depress button s3 to return to normal time.
CHRONOGRAPH
8. depress button s3, it reads minutes/seconds/1/100 seconds.
9. Depress button s1, the chronometer starts counting. The 1/100 second flag starts flashing when less than 30 or 40 minutes option.
10. Depress button s2 to split time. The lap flag starts flashing, and the chronometer is still actually counting. Depress button s2 again to release the split time.
11. Depress button s1 again to stop counting, and the stop flag starts flashing. To reset the chronometer 20, depress button s2. Depress button s3 to return to normal time mode.
If this does not work can I get the 3 diget # on the back of the watch.
Good Luck
