SOURCE: Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
SOURCE: Ice forming on refrigerant lines and melting onto
Hi, it could be slightly over charge with freon, you can insulate line with foam insulation, check ref. store, for insulation or be creative.
SOURCE: my whirlpool gold side by side refrigerator forms
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
SOURCE: I have a refrigerator model
it sounds like the freezer drain is pluged . try cleaning it with hot water and a turkey baster . and if this problem does't go away and the ice comes back you may have a defrost problem . .. mm hope this helps .. feed back pls ..
