SOURCE: You got the solution for DX150
Dear Nitingupta4u,
During display message "please wait" in DAV-DX150, there is problem have been observed in Optical Lens. If the Sled-Mechanism of Optical Lens doesn't work properly, this message "please wait" will be display. Your home theater has complicated disc loadimg mechanism and a skilled person can fix this problem. Please contact your nearest Sony service shop.
SOURCE: SONY DAV-DZ720
you are stupid for asking me how i did it, did you give me solution, nonsense.
i hate you all.
SOURCE: SONY DAV-FX900KW - I am
there is a small circle just beneath the CD tray. If you click it using a toothpick or any tiny device, it will help eject the disk. I have tried that and it works... There might be a problem on the roller inside the disk tray, wherein it requires a technician to repair such device...
SOURCE: Getting an error display as
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
For more details, just type in the site name "Electro-help" to
your search engines' search box [not in the address bar of your browser],
and click search. It is an electronic
equipments service help site. All
details you want are there. Note
the position of hyphen in between words in site name, when you type it
in. The site will appear as it
is in web; subtitled as Service help to electronic home entertainment
equipments.
Pull up older posts.
You can get all details.
You can locate it
either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and
bottom of each post might help you to get details about the availability of
spare parts; price etc:-
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
