Question about SanDisk Sansa Clip MP3 Player
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Posted by grant7059 on
Anonymous
    New Friend:
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
Posted on Nov 16, 2010
My computer does not recognise my sandisk sansa clip.i dont have a driver and i have windows xp.what to do?
Have you tried the following unplug the USB cable, lock the device, push the round button in the middle of the Sansa player, and while holding it, plug in again the USB cable
May 29, 2011 | SanDisk Sansa Clip MP3 Player
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip has just died
Apparently the Sansa clip 4gb mp3 has a hardware problem and frequently just stops working. I have asked Amazon for a replacement. Thanks anyway
Nov 19, 2009 | SanDisk Audio Players & Recorders
My computer will not recognise SanDisk Clip
See if you can download the driver for it on Sandisks site, this should make it possible for your computer to recognize it. You may also want to try a different usb cord, USB cords go faulty quite easily.
Nov 08, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 4gb clip purchased will not hold charge
You should and just tell them that the battery is deffected
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
My sansa clip ipod is not recognised by any computer
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just n case.
Hope this helps!
Jul 22, 2009 | SanDisk Sansa Clip MP3 Player
SANSA 4GB PLAYER
Have you tried updating your Windows Media Player to number 11? this has the drivers for SansaClip. Go to windows website, download WMP 11 and then plug in Sansa and uyour computer should recognise it. Good luck.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
How do you dowload music on a sansa shaker chip
connect the sansa via usb to the computer and copy your music to the device once acknowleged by the computer.
Dec 27, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
151 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
