Vizio VW32L 32 in. LCD HDTV Logo
Posted on Nov 15, 2010
Tv turns on but get only a black screen no sound remote will not work and only way to turn it off is by unplugging it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
714
Points
SOLUTION FOR VIZIO E322VL 32" LCD HDTV WITH INTERNET APPS.
SELECT: MENU
USE REMOTE AND ENTER 2,4,8,9
SELECT: CLEAR MEMORY, THEN ,
SELECT: YES
IT CLEARS ORIGINAL SET-UP, WHICH YOU WILL HAVE TO DO AGAIN,, BUT IT WILL CLEAR UP SEVERAL PROBLEMS, I.E., ON/FF BUTTON FREEZES, VIDEO IMAGE FREEZES, BUT AUDIO OKAY, SCATTERED COLOR BARS OR FLICKERING VIDEO IMAGES, PULL AC PLUG TO TURN-OF/ON DUE TO REMOTE FREEZING, ETC.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
714
Points
Make sure you don't have it on energy saver for that if setting up in store
3 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 03, 2009
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Anonymous
  • 13 Answers
  • Posted on Jan 22, 2010
SOURCE: my vizio vx32L turns on but only a black screen shows up
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Anonymous
  • Posted on Feb 14, 2010
SOURCE: We have a Vizio model # GV47LFHDTV10A. When we
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
Why can I not get my tv to turn back on after it shutdown on its own?
There will be a fault somewhere, probably in the power supply and the tv has shut down into protection mode to safegaurd other components
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
5helpful
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
2answers
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
2answers
Our TV reset itsself to sales pitch
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
2answers
Power, audio and video peob;em
go to menu and put the video into the right spot and check with your audio setup menu.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
