Question about Garden
I have a stanley garage door opener model # ST205.A09 When it opens it goes up too far and when it closes it comes down with alot of force. When this first started it went up about 2 feet then came down. I tried to reset the open and close settings but now I have the problem with it having too much travel or force going up and down. Thanks for your help
Posted by sneitzel846 on
Jeff Bonvallet
    Scholar:
  • 41 Answers
Make sure the counter balance springs are ok. Most garage doors have 2 springs to provide counter balance for the door. Your garge door opener may have enough power to still operate even with one springs broken however with one springs broken would hit pretty hard. It the springs look ok I would release the door from the opener (while in the down position) using the little rope that hangs down and operate the door by hand to ensure it goes up and down smoothly. Most problems are due to friction caused by bad rollers or failed springs. If this is not the issue let me know.
Hope this helps
Posted on Nov 15, 2010
I have a Stanley garage door opener model 8500. I replaced the door and now my operate button doesn't work. Is there a reset?
If the door is heaver than the original you may to adjust the opening force and the closing force. Check your instructions. The closest gdo I found was a chamberlain 8500. Go online to
Elite Series 8500 Garage Door Openers LiftMaster and see if this the same unit. The instructions can viewed . Good Luck
Jul 20, 2017 | Building Materials
Garage door
There should be two screw slots on the side/end of the lifter motor unit.
One is for how much force to close, the other how far down it comes.
Adjust the one for how far down it goes.
Jul 17, 2013 | Building Materials
I have a craftsman garage door opener. Model number 4184315 7D When I close the garage door it will automaticly open by it's self. There is nothing obstructing the sensor that prevents the door from...
There are two sets of adjustments. Down position and down force, If the travel is set to far in the down position the max down force setting will trip and the door goes back up.
Adjust he down position until a slight gap is visible in the down position. Adjust slight steps until no gap is visible.
If return trips increase the down force slightly . Position adjustments are on the side, down force blue knobs on back. Note adjustment positions before beginning so if you get confused you can start over.
Hope this helps?
Jun 23, 2017 | Kitchen Ranges
Door comes down and goes right back up. then the lite blinks 4 times with a click noise. the safety eyes also are not on
It sounds like you need to adjust your down limit switch and/or perhaps your motor force settings. If the limit switch is not in the sweet spot along the rail it can be triggering too soon or not in time. In your case it could be too far down the rail and thus not stopping/slowing the motor in time. Your door is then being pushed against the floor too hard. Your safety/return force is goes way over limit and tells the opener to go back. While closing your door look at your rail and if its bending when the door hits the ground, this is definitely happening. After finding the sweet spot for your down limit switch, you can readjust your return/safety force per your opener manual.
Jan 03, 2011 | Chamberlain 12HP Power Drive Chain Drive...
I have a new garage door opener that has the black and purple buttons to adjust the force and travel of the door ...... eveything is working well except when the door closes it goes a little to far, the...
I have a feeling the down force adjustment is set much to high. If the door is hitting the floor hard enough to bend the rail the safety should be reversing the door to the open position. Maybe this will help.
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Nov 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Does a Chamberlain wireless Klika2 work with a Whistler Mod nr ST205.A09 ? If yes, which ID do I use.... & does not work...
I understand the Whistler was mad by Stanley. If yours was made after 1998 the KLIK2U will work with it. Follow the steps under Type 4.
Aug 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage door starts to close and then opens up
I had a simular issue, except mine was that the previous owner decided to mess with all the settings and mounts and screwed everything up.
The problem isn't your force sensors its your downwards stopping sensor on the opposite side of the opener. For me I had to take the entire panel off and replace the sensor back in its holder, but try adjusting that sensor setting (clockwise goes down, counterclockwise goes up).
If that doesn't work then i dunno:)
Also set both force settings in between 0-1, for some reason with mine if i set it higher it would set them off....
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
